ERROR
The spatial reference of all map layers must match
Error Message
After creating a tile package for ArcGIS for Windows Mobile, the following error is displayed:
"Error: The spatial reference of all map layers must match."
Cause
When a tile package is created using the default tiling scheme for ArcGIS Online / Bing Maps / Google maps, the tile package is automatically set to WGS 1984 Web Mercator (Auxiliary Sphere) instead of the original coordinate system.
Solution or Workaround
To use a format other than WGS84 Web Mercator, base the tiling scheme on an existing map cache, or create a new tiling scheme. To create a tiling scheme, follow these steps:
  1. Open ArcToolbox and browse to the Server Tools > Caching. Open the Generate Map Server Cache Tiling Scheme tool.
  2. Under Map Document, browse to the location of the map, and under Output Tiling Scheme designate the location where it is to be saved.
    [O-Image]
  3. Choose the number of scales to be used. The tool automatically creates the scales based on the extent of the MXD, or they can be entered manually.
  4. Click OK to commit the changes and close the dialog box.
Article ID:000011801
Software:
  • ArcGIS Server
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
