English
How To: Automate the export of rasters from an SDE raster catalog
Summary
GIS managers and administrators sometimes need to automate the process of exporting rasters from SDE raster catalogs to raster datasets on disk. Instructions provided describe how to do this.
Procedure
The below Python script demonstrates how to automate the export of raster datasets from an SDE raster catalog to a raster dataset on disk. The background value is also set to zero in the below script.
  1. Modify the parameters below according to the environment:
    workspace = r"Database Connections\lclinton2_SQL08_R2.sde\sde101.SDE.Prasanta"
    outras = r"C:\Data\outrasters"
  2. Code:
    import arcpy, os, string
    def ExtractRasterFromRC(workspace,outras):
    count = arcpy.GetCount_management(workspace)
    str_cnt = str(count)
    int_cnt = int(str_cnt)
    cnt = 1
    while cnt <= int_cnt:
    raster = workspace + os.sep + "Raster.OBJECTID=" + str(cnt)
    name = "tiff_" + str(cnt) + ".tif"
    name_out = outras + os.sep + name
    print "Reading {0}".format(raster)
    arcpy.CopyRaster_management(raster,name_out,"DEFAULTS","0","0","","","8_BIT_UNSIGNED")
    print "Copied {0}".format(name_out)
    cnt += 1
    if __name__=="__main__":
