HOW TO
Convert a multipatch surface into a TIN
Summary
Instructions provided show the steps to convert a multipatch surface to a TIN (or other surface type).
[O-Image]
Procedure
  1. Open the Feature Vertices to Points tool and use the multipatch feature as the input to create a point feature class.
    The output point features have Z-values stored in their geometry.
  2. Open the Create TIN tool and use these points as the Input Feature Class. Use Shape.Z as the Height Field, and click OK to complete the conversion.
Article ID:000011752
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
