HOW TO
Automate deleting of objects owned by a schema
Summary
GIS managers and administrators sometimes need to delete all feature datasets, feature classes and tables from a database owned by a particular schema.
Procedure
The below Python script provides an automated way of deleting feature datasets, feature classes and tables from a database owned by a particular schema.
  1. Modify the variables below according to the environment. The variables are located below main statement:
    logWorkspace = "C:/Temp"
    workspace = "C:/connections/LOCATOR_CONN/DATAOWNER.sde"
    dLogName = "Log_dataset_del.txt"
    fLogName = "Log_fc_del.txt"
    tLogName = "Log_table_del.txt"
    schema = "sde.DATAOWNER"
    schema=DATAOWNER is case-sensitive:
    • Oracle: DATAOWNER
    • SQL Server: db_name.DATAOWNER
    • PostgreSQL: db_name.DATAOWNER
  2. Code:
    import arcpy, os, string
    def DelDatasets(logWorkspace,dLogName,workspace,schema):
    logfile = open(os.path.join(logWorkspace, dLogName), 'w')
    arcpy.env.workspace = workspace
    datasetList = arcpy.ListDatasets()
    for dataset in datasetList:
    if dataset.startswith(schema):
    arcpy.Delete_management(dataset)
    print ("Deleted Feature dataset {0}".format(dataset))
    logfile.write("Deleted Feature dataset {0}".format(dataset))
    logfile.write("\n")
    logfile.close()
    del logfile, datasetList
    def DelFeatureClasses(logWorkspace,fLogName,workspace,schema):
    logfile = open(os.path.join(logWorkspace, fLogName), 'w')
    fcList = arcpy.ListFeatureClasses()
    for fc in fcList:
    if fc.startswith(schema):
    arcpy.Delete_management(fc)
    print ("Deleted feature class {0}".format(fc))
    logfile.write("Deleted feature class {0}".format(fc))
    logfile.write("\n")
    logfile.close()
    del logfile, fcList
    def DelTables(logWorkspace,tLogName,workspace,schema):
    logfile = open(os.path.join(logWorkspace, tLogName), 'w')
    tableList = arcpy.ListTables()
    for table in tableList:
    if table.startswith(schema):
    arcpy.Delete_management(table)
    print ("Deleted table {0}".format(table))
    logfile.write("Deleted table {0}".format(table))
    logfile.write("\n")
    logfile.close()
    del logfile, tableList
    if __name__ == "__main__":
Article ID:000011747
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
