PROBLEM
Software Authorization Wizard fonts in Arabic or Asian locales do not display as expected
When running the ArcGIS for Server Software Authorization Wizard on RedHat Enterprise Linux (RHEL), some glyphs in the dialog fonts display as squares in certain locales.
This problem is only seen in the Software Authorization Wizard dialog. For example:
[O-Image] Japanese1
[O-Image] Japanese
Cause
This problem involves a font-substituting mechanism in dialogs. There is a notable lack of suitable replacement TrueType fonts for the Asian and Arabic locales.
Solution or Workaround
To improve the appearance of Asian or Arabic TrueType fonts, it is recommended that users install the 'msttcorefonts' package, available from SourceForge.net.
Ask the system administrator or, as root, download and install 'msttcorefonts' on the local RedHat Linux Server (RHLS) machine.
  1. Download the 'msttcorefonts rpm' installer.
    Code:
    #wget http://sourceforge.net/projects/mscorefonts2/files/rpms/msttcore-fonts-installer-2.2-1.noarch.rpm
  2. Install 'msttcorefonts'.
    Code:
    #rpm –Uvh msttcore-fonts-installer-2.2-1.noarch.rpm
  3. Check the fonts directory for new TrueType font files.
    Code:
    #ls -l /usr/share/fonts/msttcore/
  4. Restart the machine and log back in to the user's account.
    Code:
    #reboot
Article ID:000011722
Software:
  • ArcGIS Server
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
