PROBLEM
SQL Server 2012 replication errors
When using geodatabase replication with SQL Server 2012, two issues may be encountered:
• When synchronizing a two-way replica, duplicate Global IDs are generated when conflicts are present.
• Importing changes to a replica fails with a 'dbms table not found' error.
Cause
These issues are specific to SQL Server 2012 and are related to changes in the way local temporary tables are handled.
Solution or Workaround
There is no workaround for these issues. A fix is available in the ArcGIS 10.1 SP1 for (Desktop, Engine, Server) SQL Server 2012 Support Patch.
    Article ID:000011717
    Software:
    • ArcGIS Server
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Related Information
    Discover more on this topic
