PROBLEM
ArcObjects can be used to check out ArcGIS for Server licenses from an ArcGIS Engine application; however, there may be an issue that prevents ArcGIS 10.1 for Server licenses from being checked out.
This issue can be caused by one of the following:
In ArcGIS 10, a stand-alone ArcGIS Engine application needs to be explicitly bound to a specific ArcGIS product to use ArcObjects. To check out an ArcGIS Server license, bind the ArcGIS Engine application to the ArcGIS for Server product; do not bind to ArcGIS for Desktop or ArcGIS Engine.
Code:
RuntimeManager.Bind(ProductCode.Server)
Get help from ArcGIS experts
Download the Esri Support App
