PROBLEM
Unable to save a toolbox created in ArcGIS 10.1 to an earlier version
When trying to save a toolbox created in ArcGIS 10.1 to an earlier version, the dialog window opens and allows the user to name the new toolbox, but after clicking OK, the new toolbox is not created.
Cause
Special characters are present in the toolbox name. This is common if the toolbox has a period in the name, such as: 'MySpecial10.1tools.tbx'
The period prevents the toolbox from being saved properly.
Solution or Workaround
To resolve this issue do the following:
1. Rename the toolbox using only alphanumeric characters.
2. Repeat the 'Save As' steps and save the toolbox to the desired version.
When the folder is refreshed the new toolbox should be present.
    Article ID:000011692
    Software:
    • ArcMap
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Related Information
    Discover more on this topic
