English
How To: Automate reconcile, post and compress processes
Summary
Reconciling and posting versions in a multi-tiered versioning workflow such as: child to parent to default followed by compress is a typical workflow performed by GIS administrators or managers.
Procedure
The Python script below provides a method for automating the reconcile, post, and compress workflow. The workflow assumes three tiers (Default > Parent > Child), such that child versions are reconciled to parent version and parent versions are reconciled to default.
The script also compresses the geodatabase to state 0, deletes all versions except DEFAULT and re-creates the child versions.
  1. Modify the vtree variable in the script according to the version tree.
    For example, populate parent and child versions in the following manner:'Parent':'Child', etc. Do not list DEFAULT.
    In the example below, the version named SDE.Child is a child of SDE.Parent. The version named SDE.Edit is a child of SDE.QA.
    Example:
    vTree = {'SDE.Parent':'SDE.Child','SDE.QA':'SDE.Edit'}
  2. Set the workspace variable to reference the path to the sde connection file. Be sure the sde connection file user is the SDE Administrator:
    Example:
    workspace = r"Database Connections\MXD2.sde"
  3. Set the defaultVersion variable to reference either the dbo.DEFAULT or sde.DEFAULT in accordance to the environment.
    Example:
    defaultVersion = "sde.DEFAULT"
  4. Finally, set the logging variables according to your preference, that is, the naming convention and location of the logs.
    Example:
    logName = "RecPostLog.txt"
    logName2 = "RecPostDefaultLog.txt"
    logName3 = "CompressLog.txt"
    logWorkspace = r"C:\temp"
  5. Code:
    #Reconcile and posting versions at 10.0
    import arcpy, os, sys, string
    #Populate parent and child versions in the following manner('Parent':'Child', etc). DO NOT LIST DEFAULT
    #Reconcile and post child versions with parent
    def RecPostNonDefault(workspace,logWorkspace,logName):
    outLog = open(os.path.join(logWorkspace, logName), 'w')
    for key, val in vTree.iteritems():
    arcpy.ReconcileVersion_management(workspace, val, key,"BY_OBJECT", "FAVOR_TARGET_VERSION", "NO_LOCK_AQUIRED", "NO_ABORT", "POST")
    print "Reconciling and posting {0} to {1}".format(val, key)
    outLog.write("Reconciling and posting {0} to {1}".format(val, key))
    outLog.write("\n")
    outLog.close()
    del outLog, key, val
    #Reconcile and post with parent
    def RecPostDefault(workspace,logWorkspace,logName2,defaultVersion):
    outLog = open(os.path.join(logWorkspace, logName2), 'w')
    #Reconcile and post parents with DEFAULT
    arcpy.ReconcileVersion_management(workspace, key, defaultVersion,"BY_OBJECT", "FAVOR_TARGET_VERSION", "NO_LOCK_AQUIRED", "NO_ABORT", "POST")
    print "Reconciling and posting {0} to DEFAULT".format(key)
    outLog.write("Reconciling and posting {0} to DEFAULT".format(key))
    outLog.write("\n")
    outLog.close()
    def DeleteChildVersions(workspace):
    arcpy.ClearWorkspaceCache_management()
    arcpy.DeleteVersion_management(workspace, val)
    print "Deleted {0}".format(val)
    def DeleteParentVersions(workspace):
    arcpy.DeleteVersion_management(workspace, key)
    print "Deleted {0}".format(key)
    #Compress database
    def Compress(workspace,logWorkspace,logName3):
    outLog = open(os.path.join(logWorkspace, logName3), 'w')
    arcpy.Compress_management(workspace)
    print ("Compressed database {0}".format(workspace))
    outLog.write("Compressed database {0}".format(workspace))
    outLog.close()
    def RecreateVersions(workspace, defaultVersion):
    arcpy.CreateVersion_management(workspace,defaultVersion, key[4:], "PUBLIC")
    print "Created version {0}".format(key)
    arcpy.CreateVersion_management(workspace, key, val[4:], "PUBLIC")
    print "Created version {0}".format(val)
    if __name__=="__main__":
