English
How To: Check validity of features for all feature classes in a database
Summary
GIS administrators sometimes need to perform quality assurance checks for the validity of features.
Instructions provided describe an example of how to use a Python script to do this for all the feature classes in a database.
Procedure
  1. Modify the following parameters according to the appropriate environment for the Python script in Step 2:
    A) Set the workspace equal to the spatial database connection:
    Code:
    arcpy.env.workspace = r"Database Connections\sde_geodatabase.sde"
    B) Give the logName parameter a name:
    Code:
    logName = "FeatureInfo.txt"
    C) Set a file location for the output log file for parameter logWorkspace:
    Code:
    logWorkspace = r"C:\logs"
    D) Set the direct connect string or application service connection port for the instance parameter:
    Code:
    instance = 'sde:oracle10g:ora10gr2'
    E) Set the user:
    Code:
    user = 'sde'
    F) Set the password:
    Code:
    psswd = 'sde'
  2. Code:
    import os, subprocess, arcpy, string, sys, os
    def describeFeatures(sdeWorkspace,logWorkspace, logName,instance,user,psswd):
    logfile = open(os.path.join(logWorkspace, logName), 'w')
    for dataset in arcpy.ListDatasets():
    arcpy.env.workspace = sdeWorkspace + os.sep + dataset
    for fc in arcpy.ListFeatureClasses():
    args = ['sdelayer', '-o', 'feature_info', '-l', str(fc) + ',SHAPE','-i', instance, '-u', user, '-p', psswd]
    p = subprocess.Popen(args, stdout=subprocess.PIPE)
    output = p.stdout.read()
    logfile.write(dataset)
    logfile.write(fc)
    logfile.write(output)
    logfile.write("\n")
    print dataset, fc, output
    logfile.close()
    if __name__=="__main__":
    sdeWorkspace = arcpy.env.workspace
    logName = "FeatureInfo3.txt"
    user = 'sde'
    psswd = 'sde'
