ERROR
During the process of enabling the Local Government Information Model (LGIM) on an existing 10.1 SP1 parcel fabric, the following error message may be received if there is a conflict with an existing field using a different data type in the existing parcel fabric schema:
"Field error: Field: FloorDesignator has incorrect type on table ParcelFabric_Parcels.
Field type should be small integer."
Error during Enabling the Local Government Information model on a 10.1 sp1 parcel fabric.
In the process of enabling the LGIM, a FloorDesignator field is added as an integer data type. If a FloorDesignator field already exists in the parcel fabric with a different data type (text, for example), the process fails.
Get help from ArcGIS experts
Download the Esri Support App
