English
FAQ: Authorizing, deauthorizing, and upgrading with ArcGIS License Manager
Question
Answer
[O-Image] UK Flag
This article was contributed by Esri UK, the Esri distributor for the United Kingdom.
This index provides a list of articles that describe authorizing, deauthorizing, and upgrading with ArcGIS License Manager.
Authorizing
• HowTo: Download, extract, uninstall, install, and authorize ArcGIS License Manager 10
<a href='http://support.esri.com/en/knowledgebase/techarticles/detail/38854' target='_blank'>How To: Download, extract, uninstall, install, and authorize ArcGIS License Manager 10</a>
• HowTo: Authorize ArcGIS License Manager 10 offline (by way of email or file upload)
<a href='http://support.esri.com/en/knowledgebase/techarticles/detail/38200' target='_blank'>How To: Authorize ArcGIS License Manager 10 offline (by way of email or file upload)</a>
• HowTo: How to use ArcGIS License Manager to authorize ArcGIS products and extensions online
<a href='http://support.esri.com/en/knowledgebase/techarticles/detail/38870' target='_blank'>How To: Use ArcGIS License Manager to authorize ArcGIS products and extensions online</a>
• HowTo: Silently authorize ArcGIS License Manager 10.x on Linux
<a href='http://support.esri.com/en/knowledgebase/techarticles/detail/38412' target='_blank'>How To: Silently authorize ArcGIS License Manager 10.x on Linux</a>
• HowTo: Activate and authorize the ArcGIS Desktop 10 Evaluation software for the Education and Esri Press Edition
<a href='http://support.esri.com/en/knowledgebase/techarticles/detail/38655' target='_blank'>How To: Activate and authorize the ArcGIS Desktop 10 Evaluation software for the Education and Esri Press Edition</a>
• HowTo: Set up VBA in ArcGIS 10: Concurrent use and single use licenses
<a href='http://support.esri.com/en/knowledgebase/techarticles/detail/40201' target='_blank'>How To: Set up VBA in ArcGIS 10: Concurrent use and single use licenses</a>
• HowTo: Setting up Child License Managers from a Parent license server
<a href='http://support.esri.com/en/knowledgebase/techarticles/detail/38973' target='_blank'>How To: Setting up Child License Managers from a Parent license server</a>
• FAQ: What port is necessary to have opened to authorize ArcGIS License Manager?
<a href='http://support.esri.com/en/knowledgebase/techarticles/detail/39647' target='_blank'>FAQ: What port is necessary to have opened to authorize ArcGIS License Manager?</a>
Authorization Troubleshooting
• Error: Error: Unable to prepare your authorization
<a href='http://support.esri.com/en/knowledgebase/techarticles/detail/39553' target='_blank'>Error: Error: Unable to prepare your authorization</a>
• Error: 7252:Line items belonging to different customer organization cannot be activated together
<a href='http://support.esri.com/en/knowledgebase/techarticles/detail/38826' target='_blank'>Error: 7252:Line items belonging to different customer organization cannot be activated together</a>
• Problem: What should be done with the *.dat file that is received from authorize@esri.com?
<a href='http://support.esri.com/en/knowledgebase/techarticles/detail/38309' target='_blank'>Problem: What should be done with the *.dat file that is received from authorize@esri.com?</a>
Deauthorizing
• Error: "Input parameter hostId of TrustedHostEntityBO.createTrustedHostEntityBO cannot be null" when authorizing ArcGIS License Manager 10.0 SP2 in Amazon
<a href='http://support.esri.com/en/knowledgebase/techarticles/detail/38948' target='_blank'>Error: "Input parameter hostId of TrustedHostEntityBO.createTrustedHostEntityBO cannot be null" when authorizing ArcGIS License Manager 10.0 SP2 in Amazon</a>
Upgrading
• HowTo: Upgrade licenses for ArcGIS Desktop 10 to Version 10.1
<a href='http://support.esri.com/en/knowledgebase/techarticles/detail/40383' target='_blank'>How To: Upgrade licenses for ArcGIS Desktop 10 to Version 10.1</a>
• HowTo: Use Survey Analyst, Tapestry, PLTS MPS Atlas, and PLTS Mapping Agency in ArcGIS Desktop Concurrent Use 9.3.1 with an ArcGIS License Manager 10
<a href='http://support.esri.com/en/knowledgebase/techarticles/detail/38391' target='_blank'>How To: Use Survey Analyst, Tapestry, PLTS MPS Atlas, and PLTS Mapping Agency in ArcGIS Desktop Concurrent Use 9.3.1 with an ArcGIS License Manager 10</a>
Related Information
