English
Bug: ArcSDE 10 for Informix Post-Installation GUI fails with SQL syntax error when defining the SDE user environment
The ArcSDE 10 for Informix Post-Installation GUI fails with a SQL syntax error when defining the SDE user environment.
Cause
Incorrect format specifier for '%' in call to SES_wsprintf:
SES_wsprintf((SE_WCHAR *)sqlStmt, "SELECT bld_id FROM sysbldregistered WHERE bld_id LIKE 'spatial.8.%s' ; ", percent);
Workaround
Run the post-installer for ArcSDE 10 for Informix.
  1. Select Custom and click Next.
  2. Un-check the option to 'Define SDE User Environment.'
  3. Click Next and continue with the remaining steps in the post-installer.
