PROBLEM
When calculating statistics for a field after a one-to-many join, the values are larger than prior to the join
After conducting a one-to-many join, the statistics values for a number field increase when compared to the pre-join values.
Cause
In a one-to-many join, only the first matching record is joined and displayed in the layer's attribute table. However, when using some tools, the subsequent joined records are used in calculations.
This means that even though only the first record is joined and displayed, when calculating statistics for a field all values are included.
In ArcMap 10.1, when exporting or using the Feature Class To Feature Class conversion tool on a feature class with a 1:M join, the resulting output contains all values and not just the first matching record.
Solution or Workaround
There are a few methods for working around this issue.
  • It is recommended to use a relate or relationship class instead of a 1:M join.
  • If creating the 1:M join is the only option, it may be best to do field calculations and statistics prior to the join.
Article ID:000011639
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
