English
How To: Apply an outline symbology to extruded polygons
Summary
When extruding polygons in ArcScene or ArcGlobe, the outline symbology does not get applied.
[O-Image]
Instructions provided show how to create the visual effect of having a colored border on extruded polygons.
Procedure
  1. Convert the polygon feature class to a polyline feature class using the Polygon to Line tool.
    [O-Image]
  2. Buffer the polygon layer by a small negative value to reduce the footprint of the polygons.
    [O-Image]
  3. Adjust the outline width of the polyline layer and apply the extrusion value to both the polygon buffer and polyline layers. Displaying both layers provides the desired results.
    [O-Image]
