BUG
NIM078808: Compress_log table can be seen in the database connection after compressing the database
When establishing a database connection after performing a compress within a geodatabase, the compress_log table is visible to the SDE or geodatabase administrator.
Cause
The visibility of the compress_log table within the database connection is as designed. At version 10.1, the compress_log table is visible in the database connection as a table for the SDE or administrative users associated with the db_owner database role in the geodatabase. Non-administrative users are not able to view this table in their database connection unless they are granted permission by the SDE or administrative user.
Workaround
Connect to the database as a non-administrative user and the compress_log table is not visible in the database connection.
10.1 Help - The geodatabase compress operation
    Article ID:000011604
    Software:
    • Legacy Products
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
