BUG
Adding a basemap changes the coordinate system of the data frame to Web Mercator (auxiliary sphere)
Last Published: March 15, 2022
When adding a basemap to ArcMap 10.1 using the Add Basemap dialog, the map display is not refreshed and the coordinate system of the data frame is changed to WGS 1984 Web Mercator (auxiliary sphere).
Cause
WGS 1984 Web Mercator (auxiliary sphere) is the spatial reference of the basemap layers available in the Add Basemap dialog. This bug causes the data frame to change to this spatial reference when adding layers using this dialog.
Workaround
  1. Navigate to the View menu > Data Frame Properties > Coordinate System and change the coordinate system back to the correct spatial reference.
  2. If working with the same basemap layer frequently, the basemap layer can be saved as a layer file. In the Table Of Contents, in either the Drawing Order view or the Visibility view, right-click the basemap layer > Save As Layer File. The next time this basemap layer is needed, browse to the saved layer file (.lyr) and add it to the map. This method of adding the basemap does not change the data frame coordinate system.
Article ID:000011601
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
