ERROR
Failed to create the site. Failed to create the service 'System/CachingTools.GPServer'
Error Message
After installing ArcGIS for Server on a Linux operating system, attempting to create the site fails with the error:
"Failed to create the site. Failed to create the service 'System/CachingTools.GPServer'."
Any subsequent attempts to create the site also fail with the same error.
Cause
This occurs when installing ArcGIS for Server to an installation location containing multi-byte characters in the path. The site creation process fails because ArcGIS Server cannot access the necessary site resources under the installation directory.
Solution or Workaround
Uninstall ArcGIS for Server and re-install to a location that does not contain multi-byte characters.
Article ID:000011598
Software:
  • ArcGIS Server
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
