English
Problem: Cannot edit a feature in ArcGIS for Windows Mobile 3
Open an ArcGIS Mobile project, select collect features task to add or edit features. The select geometry dialog opens and there is nothing to select, cannot edit the feature.
Cause
To edit a feature in ArcGIS Mobile, the feature must:
• Be a feature class in a geodatabase.
• Have Global IDs.
Solution or Workaround
Do one of the following:
• Follow the procedure to add Global IDs.
1. Open ArcCatalog.
2. Navigate to the feature class.
3. Right-click the feature class > Add GlobalIDs...
or
• Use the Add Global IDs tool.
    Related Information
