English
How To: Restore an ArcSDE database from Oracle RAC to a non-clustered environment
Summary
Moving the ArcSDE database back from the RAC (clustered environment) to a non-clustered environment only involves resetting the 'sde.state_id_generator_nc' sequence.
Procedure
To migrate an SDE database back to a non-clustered environment from an RAC environment, update the state_id_generator_nc sequence as follows:
  1. Log in to SQL*Plus or SQL Developer as SDE.
  2. Run the code listed below to update the state_id_generator_nc:
    Code:
    BEGIN
    DECLARE
    STATE_ID_MAX NUMBER := 0;
    SEQ_VAL NUMBER := 0;
    L_DIFF NUMBER := 0;
    BEGIN
    SELECT MAX (STATE_ID) INTO STATE_ID_MAX FROM STATES;
    SELECT state_id_generator_nc.NEXTVAL INTO SEQ_VAL FROM DUAL;
    IF SEQ_VAL < STATE_ID_MAX then
    L_DIFF := STATE_ID_MAX - SEQ_VAL;
    EXECUTE IMMEDIATE 'ALTER SEQUENCE state_id_generator_nc INCREMENT BY ' || L_DIFF;
    EXECUTE IMMEDIATE 'ALTER SEQUENCE state_id_generator_nc INCREMENT BY 1' ;
    END IF;
    END;
    END;
  3. Commit the code.
