English
FAQ: Where are the ArcGIS crash dump files saved when an error report is generated?
Question
Answer
When using the Windows Vista or Windows 7 operating systems, the crash dump files (.dmp) can be found at the following local hard drive location within the application data of the user profile:
ArcGIS 10.0:
C:\Users\<username>\AppData\Roaming\ESRI\ErrorReports
ArcGIS for Desktop 10.1, 10.2, 10.2.1, 10.2.2, 10.3, ArcGIS Pro 1.0:
C:\Users\<username>\AppData\Local\ESRI\ErrorReports
When using the Windows XP operating system, the crash dump files (.dmp) can be found at this location:
C:\Documents and Settings\<username>\Application Data\ESRI\ErrorReports
The ErrorReports folder is created automatically upon application crash, it may not be present after installation of a new version of ArcGIS.
All Error Reports are treated as confidential to ESRI, and their usage is covered by ESRI Privacy Policy.
Related Information
