BUG
NIM079768: Oracle enterprise geodatabase upgrade may crash if a long password and/or connection string is used
When trying to upgrade an Oracle Enterprise geodatabase to 10.0 or 10.1 through a connection that uses a long Oracle easy connection string, the upgrade may crash during the geodatabase schema update.
Cause
There is an internal string length limitation that the total length of the user password and the connection string, in combination, must be less than 31 characters. When the total length of the password and the connection exceeds this limitation, upgrade may crash due to a memory corruption.
This issue is planned to be addressed at 10.0 SP5 and 10.1 SP1.
Workaround
Create a TNS entry with a shorter length for the Oracle instance, and use the TNS entry for the geodatabase connection to perform the upgrade. Also, if needed, use a shorter password.
    Article ID:000011534
    Software:
    • ArcGIS Server
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Related Information
    Discover more on this topic
