ERROR
Upgrading a geodatabase on Oracle to version 10 fails with a "User does not have required privileges" error and indicates "Success"
Error Message
In certain situations, upgrading an enterprise geodatabase for Oracle to version 10 fails with the following error message:
"Error: User does not have required privileges to upgrade. [Success]"
The error is raised even though all the required privileges have been granted to the geodatabase admin user and the public role.
Cause
The error is unique to particular conditions within the geodatabase schema in Oracle and cannot be identified without working with Esri Customer Support.
Solution or Workaround
If this error message is encountered when trying to upgrade to Enterprise geodatabase 10.0 on Oracle, please contact Esri Technical Support.
    Article ID:000011529
    Software:
    • ArcGIS Server
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Related Information
    Discover more on this topic
