English
Bug: NIM077558: Adding a function to a mosaic dataset prevents the statistics from being cleaned
Statistics cannot be cleaned for a mosaic dataset.
Cause
After adding a mosaic dataset function, such as Stretch, Composite Bands, etc., the statistics cannot be cleaned.
Workaround
Create a new mosaic dataset and load the existing mosaic dataset rasters.
  1. Create a new mosaic dataset in the geodatabase.
  2. Add rasters to the mosaic dataset using Table as the Raster Type and the existing mosaic dataset as the input raster.
    Warning:
    Adding a function to the new mosaic dataset causes the clean statistics to fail.
Related Information
