English
How To: Compile and build WxWidgets 2.8.7 to run ArcGIS Engine samples on Linux
Summary
Instructions provided describe how to compile and build WxWidgets 2.8.7.
Procedure
These instructions must be performed on a 32-bit Linux machine that meets the system requirements for ArcGIS Engine. The resulting binaries will be usable on both 32- and 64-bit machines.
  1. Find WX 2.8.7 at the Source Forge site.
  2. Download WxWidgets to a local directory using wxWidgets-2.8.7.tar.gz (or .bz2).
  3. Unpack the source code:
    Code:
    tar -zxvf /<path to sourcecode>/wxWidgets-2.8.7.tar.gz
  4. Change directory (cd) to the unpacked wxWidgets-2.8.7 source code.
  5. Configure the source code with the following command:
    Code:
    ./configure --prefix=<installation location> --enable-unicode --with-gtk
  6. Build wxWidgets using the command:
    Code:
    make all
  7. Install wxWidgets using the command:
    Code:
    make install
    Make sure that <installation location>/bin is in the PATH so that wx-config may be executed from the project's makefiles.
Related Information
