PROBLEM
Hillshade displays as unique values
A Hillshade raster that has 25 or less unique elevation values displays as uniquely rendered, not stretched, when added to ArcMap.
Cause
All single-band rasters with 25 or less unique values display by default with a unique value renderer.
Solution or Workaround
The symbology may be changed to 'stretched' under the raster's properties. A layer file may also be created and used to save the stretch symbology.
Article ID:000011469
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
