English
Error: 010092 : Invalid output extent
Error Message
"010092 : Invalid output extent."
Cause
The extent specified, either in the environment or as a parameter, is invalid for the output that is to be created.
Solution or Workaround
Specify a valid extent for the output. If unsure what to use, set the Output extent in the Environment to Default.
    Related Information
