English
Error: 001100: Failed because no statistics is available
Error Message
"001100: Failed because no statistics is available."
Cause
Some geoprocessing raster tools, for example the Reclassify and Get Raster Properties tools, give this error when the input raster doesn't have statistics calculated. Statistics are required for rasters and mosaic datasets to perform certain tasks, such as applying a contrast stretch or classifying data.
Solution or Workaround
Calculate statistics on the input raster before using the geoprocessing tool. To calculate statistics, open ArcCatalog, right-click on the Input Raster, and select Calculate Statistics. Alternatively, navigate to ArcToolbox > Data Management tools > Raster > Raster Properties > Calculate Statistics.
    Related Information
