ERROR
This version of the Geodatabase is compatible with the dataset and cannot open it
Error Message
Using 10.0 SP2 or a later 10.0 service pack, the following error is returned when attempting to open a dataset in a 10.x geodatabase:
"This version of the Geodatabase is compatible with the dataset and cannot open it.[dataset name: <name of dataset>]"
Cause
The dataset contains functionality specific to Version 10.1. At ArcGIS 10.1, several datasets have been updated to provide new functionality. They are as follows:
• Support for Python scripting is available with annotation and dimension feature classes.
• Tables and feature classes now support editor tracking.
• Network datasets support live traffic data, soft restrictions, preferred truck routes, and Python script evaluators.
• Workflows and tools for creating and editing mosaic datasets have been improved, including improved generation of seamlines and footprints, support for more raster types, additional properties, and tools to analyze the mosaic dataset for known errors or limitations.
Solution or Workaround
Use ArcGIS 10.1 to open the dataset.
    Article ID:000011448
    Software:
    • ArcMap
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
