ERROR
000423: Only single band integer raster dataset is a valid input
Error Message
When creating a colormap or raster attribute table for a raster dataset, the following error message is returned:
Error:
Error 000423: Only single band integer raster dataset is a valid input.
Cause
Creating a colormap or raster attribute table requires the input to be a single band raster with an integer pixel type.
Solution or Workaround
Ensure that the input is a single band integer raster. To check the raster properties, right-click the raster dataset from the Catalog window, and click Properties to open the Raster Dataset Properties dialog box. The Number of Bands and Pixel Type are shown under Raster Information.
If the input raster dataset has multiple bands, refer to How To: Extract a single band from a multiple band raster to extract a single band from the raster. To change a floating pixel type raster to integer, use the Int tool and select the floating type raster as the input.
Article ID:000011447
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
