English
Error: Could not add the specified data object to the scene. Try using a smaller subset
Error Message
The following warning message is displayed when trying to add a terrain dataset to ArcScene.
"Could not add the specified data object to the scene. Try using a smaller subset."
Cause
Terrain datasets are not supported in ArcScene. Terrains are supported in ArcMap and ArcGlobe.
Solution or Workaround
To use a terrain dataset as an elevation source in ArcScene, the terrain data must be converted to a supported format using one of the following methods:
Related Information
