ERROR
SDE DBMS Error: -37 ERROR relation: "sde.sde server config" does not exist
Error Message
An error similar to the following is reported in the $SDEHOME/etc/sde_setup.log.
"[Wed Jul 27 14:56:55 2011] ev.SQLstate = 42P01 SDE DBMS Error: -37 ERROR: relation "sde.sde_server_config" does not exist"
Cause
There is a check for the existence of an object before the object is created.
Solution or Workaround
This error can be safely ignored.
    Article ID:000011394
    Software:
    • Legacy Products
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
