HOW TO
Note: This article applies to retired ArcGIS versions 9.x and 10.0. Later versions of ArcGIS may contain different functionality, as well as different names and locations for menus, commands and geoprocessing tools.
Instructions provided describe a sample Python script that can be used to calculate zonal statistics for overlapping zones.
When using polygon features as the input zones in the Zonal Statistics as Table tool, the tool rasterizes the vector features. This results in data loss if overlapping polygons are present in the zone feature.
Using Python, the tool's limitations can be overcome by iteratively processing each feature to overcome such a problem.
import arcpy, os, sys, string from arcpy import env arcpy.CheckOutExtension("spatial") def CreateDirectory(DBF_dir): if not os.path.exists(DBF_dir): os.mkdir(DBF_dir) print "created directory {0}".format(DBF_dir) def ZonalStasAsTable(fc,DBF_dir,raster,zoneField): for row in arcpy.SearchCursor(fc): lyr = "Zone_{0}_lyr".format(row.OBJECTID) tempTable = DBF_dir + os.sep + "zone_{0}.dbf".format(row.OBJECTID) arcpy.MakeFeatureLayer_management(fc, lyr, "\"OBJECTID\" = {0}".format(row.OBJECTID)) print "Creating layer {0}".format(lyr) out_layer = DBF_dir + os.sep + lyr + ".lyr" arcpy.SaveToLayerFile_management(lyr, out_layer, "ABSOLUTE") print "Saved layer file" arcpy.gp.ZonalStatisticsAsTable_sa(out_layer, zoneField, raster, tempTable, "DATA", "ALL") print "Populating zonal stats for {0}".format(lyr) del row, lyr def MergeTables(DBF_dir,zstat_table): arcpy.env.workspace = DBF_dir tableList = arcpy.ListTables() arcpy.Merge_management(tableList,zstat_table) print "Merged tables. Final zonalstat table {0} created. Located at {1}".format(zstat_table,DBF_dir) del tableList if __name__ == "__main__": ws = "C:/TEMP" DBF_dir = ws + os.sep + "DBFile" fc = "C:/TEMP/zone/zone_data/zones.gdb/zones" raster = r"C:/TEMP/zone/raster/zonalstat_DEM.img" zoneField = "ZoneID" zstat_table = DBF_dir + os.sep + "Zonalstat.dbf" CreateDirectory(DBF_dir) ZonalStasAsTable(fc,DBF_dir,raster,zoneField) MergeTables(DBF_dir,zstat_table)
Get help from ArcGIS experts
Download the Esri Support App
