English
How To: Install the FME Extension for ArcGIS to manipulate ArcPad AXF files
Summary
The instructions provided describe how to install the FME Extension for ArcGIS to manipulate ArcPad AXF files. The ability to use the Data Interoperability Extension to read the contents of an ArcPad AXF file is introduced with ArcPad 10 Service Pack 3.
Warning:
An ArcGIS Data Interoperability Extension license is required to use this functionality.
Out-of-the-box support for reading ArcPad AXF files is available in the Data Interoperability Extension starting with ArcGIS version 10.1. Until ArcGIS 10.1 is released, Safe Software (the company which develops a product called FME that the Data Interoperability Extension is built upon) is providing a temporary license of the FME ArcPad Data Interoperability Edition free-of-charge.
In ArcGIS Desktop, the FME ArcPad Data Interoperability Extension is referred to as the FME Extension for ArcGIS.
The FME Interoperability Tools toolbox replaces the Data Interoperability toolbox entirely.
Procedure
  1. Install ArcPad 10 SP3 (ArcPad 10.0 R3).
    ArcPad 10 SP3 is available for download from Esri Customer Care.
  2. Install FME 2011 SP4.
    A. Navigate to Safe Software's website FME 2011 SP4.
    B. Download and install the 32-bit version of FME 2011 SP4 from the 'Download Now' link under Step 1 on the Safe Software website.
    Warning:
    The AXF reader is only included with the 32-bit FME 2011 SP4 application. Even if a 64-bit system is being used, the 32-bit application should be installed.
    C. After the installation is complete, it automatically prompts the registration process. Proceed to Step 3 for information on registering the software.
  3. Register FME 2011 SP4.
    A. Click 'Activate' under Step 2 on the Safe Software website.
    B. Fill out the required information.
    C. Click the 'Start your Download' button at the bottom of the page to download a file called 'fmeArcPADDataInteropEdition.fmelic'.
    D. After the installation is complete, the registration wizard opens. In the registration wizard, click 'Install a license file provided by Safe Software' at the bottom of the dialog box.
    E. Navigate to the recently downloaded .fmelic file.
    F. Click 'Activate' to finish the registration.
  4. Activate the extension.
    A. In ArcMap and ArcCatalog, go to the Customize Menu > Extensions list. The Data Interoperability Extension is now listed as the FME Extension for ArcGIS.
    B. Click the checkbox to activate the extension.
  5. Add the FME Interoperability Tools to ArcToolbox.
    A. Open ArcToolbox.
    B. Right-click ArcToolbox and select Add Toolbox.
    C. In the Add Toolbox dialog box, navigate to C:\Program Files\ArcGIS\Desktop10.0\ArcToolbox\Toolboxes\FME Interoperability Tools.tbx and click Open.
Related Information
