English
Problem: Number of shapes does not match the number of table records
Solution or Workaround
The articles below both contain suggestions for resolving the error "Number of shapes does not match the number of table records" received when adding a shapefile to ArcMap, or to ArcView GIS.
Some of the following articles suggest the usage of the ShapeFile Repairer utility.
For the ShapeFile Repairer Utility to work correctly, ensure the language setting of the computer matches the language used to create the shapefile.
Download: ShapeFile Repairer Utility
Related Information
