HOW TO
This article was contributed by Esri Deutschland, the Esri distributor for Germany.
The instructions provided describe how to install NAS-Reader for ArcGIS Desktop 10. NAS-Reader enables importing and visualizing 3A data (AFIS®, ALKIS® and ATKIS®) by way of NAS (Normbasierte Austausch Schnittstelle), a standards-based exchange format of German surveying authorities. According to GeoInfoDok version 6.0, NAS data can be read by NAS-Reader and all schemes, including version 6.0.1, are supported.
Note: Version 5.1.1_K is an exception; it is not supported by NAS-Reader. This version was available for a short time and was replaced by version 5.1.1_K2.
The installation requires the following:
Note: Since the NAS-Reader uses only parts of the Data Interoperability extension, it is not necessary to purchase a license. Nevertheless, the full use of Data Interoperability is still dependent on an activated license.
Before Beginning
Install the Data Interoperability Extension
Install the NAS-Reader
Note: Administrator rights may be needed for this step.
Note: To adjust the Add-in go to Customize > Add-In Manager.
Data and File Information
NAS data can be imported in file geodatabases (*.gdb) or in personal geodatabases (*.mdb) and can be visualized in ArcMap. Esri recommends using a file geodatabase for large amounts of data (several hundred MB).
Get help from ArcGIS experts
Download the Esri Support App
