HOW TO
Center and maintain all features in map, while highlighting current index feature and browsing Data Driven Pages
Summary
Instructions provided describe how to center and maintain features in a map book or series while highlighting index features.
It is possible to center features in each page of a map book or map series by enabling feature-based Data Driven Pages. This can be done by simply designating the desired point, polyline, or polygon layer as an index layer under the Data Driven Pages Setup dialog. However, to maintain all the features of a map in the center of each page while browsing a map book and highlighting the feature of interest, the following workflow can be performed.
This workflow might apply in the event that it is needed to maintain the features of an entire building evacuation plan in the center of each page of a map book, while displaying different locations in a building while browsing.
This workflow may also be applicable when creating an inset map for a map book, where it is necessary to show all features and highlight the current index feature.
Procedure
  1. On the Insert menu, click Data Frame.
  2. Copy and paste the Index layer, and any other layers to be displayed in the map, into the New Data Frame.
  3. Right-click the New Data Frame, click Properties, and select the Extent Indicators tab.
  4. Click the 'Layers' (original) Data Frame.
  5. Choose the right-pointing arrow to move Layers to 'Show extent indicator for these data frames' field, click Apply and OK.
  6. Position the New Data Frame in place of the 'Layers' data frame (the data frame containing your index layer), in your layout, as shown in the following illustration:
    [O-Image]
  7. On the File menu, click Export Map.
  8. Navigate to the location to store the output PDF and name the output file 'Test_DDP'.
  9. From the 'Save as type' drop-down, choose the PDF(*.pdf) option.
  10. Under Options, click the Pages tab, select the All(pages) radio button and click Save.
    Upon opening the output PDF, note that all pages of the map book have been exported and that the feature of interest has been highlighted in each page.
Article ID:000011345
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
