English
Error: Failed to connect to database when lightweight pooling is enabled
Error Message
When using SQL Server with ArcSDE 10.x, and lightweight pooling (Fiber Mode) is enabled on SQL Server, attempting to connect to the geodatabase results in an error similar to this:
"Failed to connect to database. The release of the GeoDatabase is either invalid or out of date. DBMS table not found [Microsoft SQL Server Native Client 10.0: Invalid object name ‘sde.sde.GDB_Release’.][sde.sde.GDB_Release]"
Cause
To enable lightweight pooling, Common Language Runtime (CLR) must be disabled in SQL Server. When CLR is disabled, XML cannot be successfully queried. XML support is required for geodatabases at ArcGIS 10 and later releases. ArcSDE is unable to query the GDB schema tables in the geodatabase, as these tables have XML columns.
Solution or Workaround
To enable Common Language Runtime (CLR), it is necessary that lightweight pooling be disabled in SQL Server, as they are mutually exclusive. This allows connection to the geodatabase hosted on SQL Server.
  1. On the SQL Server instance, run a script similar to the following:
    Code:
    EXEC sp_configure 'show advanced options' , '1';
    GO
    RECONFIGURE;
    GO
    -- Disable Lightweight Pooling
    exec sp_configure 'lightweight pooling', 0;
    GO
    RECONFIGURE;
    GO
    -- Enable CLR
    EXEC sp_configure 'clr enabled' , '1'
    GO
    RECONFIGURE;
    GO
  2. Restart the SQL Server instance.
  3. Connect to the geodatabase using ArcGIS.
Related Information
