BUG
A "table was not found. [GDB_Networks]" error is raised while using INetworkWorkspace.OpenNetwork and INetworkWorkspace.GetNetworkNames methods
While using the INetworkWorkspace.OpenNetwork and INetworkWorkspace.GetNetworkNames methods a "table was not found. [GDB_Networks]" error is raised when attempting to open either a geometric network or a standalone logical network.
Cause
The ability to directly open logical networks has been removed starting at the ArcGIS 10.0 release of the geodatabase.
Workaround
If opening a logical network, use the IGeometricNetwork.Network method. If opening a geometric network, use any number of the methods on the INetworkCollection interface.
    Article ID:000011300
    Software:
    • ArcMap
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Related Information
    Discover more on this topic
