English
How To: Clip an online base map within a map document
Summary
In ArcMap, the Data Frame Properties window can be used to set the extent and visibility of an online base map or layer file for printing or exporting within the map document.
Warning:
Online base maps or layer files are not acceptable inputs for the Analysis Clip or Data Management Raster Processing Clip tool.
Procedure
The Data Frame Properties window may be accessed under the View menu in ArcMap or by right-clicking the data frame within the Table of Contents.
In the Data Frame Properties dialog, on the Data Frame tab, select the desired clip options.
[O-Image]
