BUG
ArcGIS 10.1 Final for Server install gives inaccurate warning on Red Hat Linux version 5.6
When installing ArcGIS 10.1 (Final) for Server on Red Hat Enterprise Linux (RHEL) version 5.6, the following warning is displayed:
"There is a known issue with ArcGIS Server 10.1 for Server PreRelease on RHEL 5.6. Please check Knowledge Base article 38967 for details."
Cause
This warning is incorrect.
The version of ArcGIS for Server is not a pre-release version. It is 10.1 Final.
Red Hat Linux versions prior to RHEL 5.7 are not supported by ArcGIS 10.1 for Server.
Workaround
Check the ArcGIS for Server System Requirements for supported platforms before installing ArcGIS 10.1 for Server.
Article ID:000011269
Software:
  • ArcGIS Server
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
