English
How To: Install an ArcGIS Server 9.x instance on a non-default website in IIS 6
Summary
Organizations can install their ArcGIS Server instance in a non-default website on their Windows platform. This allows the ArcGIS Server instance to be separate from the default website.
Instructions provided describe how to install a new ArcGIS Server instance on a Windows Server on a non-default website in IIS 6.
Procedure
  1. Open Internet Information Services Manager (IIS Manager).
  2. Right-click Web Sites, select New > Web Site...
    [O-Image] [O] New Web Site
  3. Click Next and type a short description in the Description text box. Click Next.
    [O-Image] Web Site Description
  4. Select an IP address from the drop down list to use for the new website.
    The default setting is 'All Unassigned'.
    If needed, type a new port number.
    If needed, type in a host header.
    Click Next.
    [O-Image] IP Address and Port Settings
  5. Type in or browse to the physical path of the new website. Click Next.
    [O-Image] Web Site Physical Path
  6. Set the website access permissions.
    Typically Read and Run scripts are allowed.
    Click Next and then click Finish.
    [O-Image] Web Site Access Permissions
  7. Run the AddInstance utility (C:\Program Files\ArcGIS\DotNet\AddInstance.exe) and enter the following:
    • ArcGIS Server Instance Name
    • IIS port number
    • Name of the Server Object Manager (SOM) machine
    • ArcGIS WebServices account and password
    Click the Add button. When finished, the ArcGIS instance folders and virtual directories are created on the new website.
    [O-Image] ArcGIS Server Instance
Related Information
