BUG
Can't get resource 'IDS_CANT_SAVE_ADDRESS_INTO_XML'
An unhandled exception is encountered using the Evaluate Site Wizard when entering an address.
[O-Image]
Cause
The user does not have write permissions to the output directory.
Workaround
This issue is resolved by adjusting the output directory permissions. This can be done in two ways.
  • Method 1: Grant the user write permissions to the existing output folder.
  • Method 2: Change the output directory to a folder to which the user has full write permissions.
    [O-Image]
Article ID:000011250
Software:
  • ArcGIS Business Analyst Desktop
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
