English
Error: Underlying DBMS error [Microsoft SQL Server Native Client 10.0: Parsing XML With internal subset DTDs not allowed. Use CONVERT with style option 2...
Error Message
When copy-pasting a specific feature dataset from an earlier version of an ArcSDE geodatabase to a 10.0 geodatabase on SQL Server 2008, the following error may be displayed:
"Underlying DBMS error [Microsoft SQL Server Native Client 10.0: Parsing XML
With internal subset DTDs not allowed. Use CONVERT with style option 2 to
Enable limited internal subset DTD support.]"
Cause
The error occurs when a dataset in the geodatabase contains a document type definition (DTD) in its metadata.
Solution or Workaround
There are two possible solutions that will allow the copy/paste to succeed:
• Remove the DTD from the metadata manually.
• Upgrade to 10.0 Service Pack 1 Desktop and then upgrade the target geodatabase to apply the latest updates to the ArcSDE stored procedures.
After either solution is performed, attempt the copy/paste again.
Related Information
