English
Error: URL should be the path to arcgisoutput directory on a machine with Business Analyst Server installed
Error Message
After executing the Upload Shapefile task in Business Analyst Server, the following error is returned: "URL should be the path to arcgisoutput directory on machine with Business Analyst Server installed."
Cause
The URL to the arcgisoutput directory may have been seen as incomplete by the Business Analyst Server if it does not include a forward slash (/) at the end of the URL.
Solution or Workaround
After replacing the incomplete URL with the complete URL, resend the request.
For example, replace "http://localhost/arcgisoutput" with "http://localhost/arcgisoutput/".
