BUG
Spatial Type for Oracle: st_intersects can fail with error ORA-028579
An ORA-028579 error can be encountered when executing a query with an st_geometry attribute.
Code:
SELECT objectid,
sde.st_intersection(shape,
(SELECT shape
FROM parcels
WHERE id = 4 AND cycle_type = '1')) AS shape
FROM parcels
WHERE sde.st_intersects(shape,
(SELECT shape
FROM parcels
WHERE id = 4 AND cycle_type = '1')) = 1;
select objectid,
ERROR at line 1:
ORA-28579: network error during callback from external procedure agent
ORA-06512: at "SDE.ST_GEOMETRY_SHAPELIB_PKG", line 682
ORA-06512: at "SDE.ST_GEOMETRY_OPERATORS", line 2496
Cause
This issue is due to an Oracle bug. Refer to My Oracle Support for more information.
Oracle Bug: 8507458 "ODCIindexstart dump on select on a column which has domain index created."
If the problem described in this article is encountered, a new folder and call stack trace file will be automatically generated by Oracle in the $ORACLE_HOME/rdbms/log/hs_core_#### folder (where #### is an auto-generated number). This call stack trace can be compared to the one mentioned in the Oracle bug, or it can be provided to Oracle to determine if the same issue is being encountered.
Workaround
This issue is fixed in the 11.2.0.2 Patch Set and some other patch releases. Refer to Oracle's support documentation for full details.
    Article ID:000011218
    Software:
    • Legacy Products
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Related Information
    Discover more on this topic
