ERROR
Failed to create the specific relationship class. Must be the owner to perform this operation
Error Message
When attempting to create a relationship class where the connected user does not own both the origin and destination tables or feature classes, the following error message is displayed:
Error:
Failed to create the specific relationship class. Must be the owner to perform this operation.
Cause
As of ArcGIS 10, the geodatabase no longer allows the creation of relationship classes between tables or feature classes not owned by the connected user. This also applies to the creation of feature-linked annotation and attachments, both of which use relationship classes.
This change was made in order to block the ability for one user to create a relationship class using a table/feature class owned by another user. This action could, in turn, prevent other users from accessing the feature class in question, since they do not have permissions on the related data.
Solution or Workaround
To create a relationship class, both the origin and destination tables/feature classes must be owned by the same user.
    Article ID:000011213
    Software:
    • ArcMap 10 x
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Related Information
    Discover more on this topic
