English
Bug: Subtypes with a defined short integer field revert back to the default value
Features collected under a subtype with a defined short integer revert back to the default subtype after synchronizing data with the server.
Cause
This is a known issue.
Workaround
Re-create the feature class and use the long integer field type instead of the short integer to define the subtype.
Related Information
