Frequently asked question
Is there a way to reset ArcLogistics Online to the normal layout?
Answer
The ArcLogistics Online layout can be reset by renaming the 'user.config' file to 'user.config.OLD' and then restarting the program.
This is similar to renaming ArcMap's 'Normal.mxt', in that it can fix many common issues with ArcLogistics Online.
The 'user.config' file may be found at the following locations:
• Windows XP:
C:\Documents and Settings\All Users\Application Data\ArcLogistics
• Windows Vista and Windows 7:
C:\ProgramData\ArcLogistics.
Article ID:000011178
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
