ERROR
Business Analyst ERROR 080002: Failed to build rings.
Error Message
An unknown exception error is encountered when running very large drive times.
[O-Image]
Cause
Business Analyst cannot process very large drive times using the detailed streets Network Analyst solver.
Solution or Workaround
Change the drive time solver from 'Detailed' to 'Hybrid'.
  1. In Business Analyst, click the toolbar and choose Preferences.
  2. In the Preferences dialog box, click the Dataset tab.
  3. Under Street Network, select the option to 'Use hybrid (performance and accuracy)'.
    [O-Image]
  4. Click OK to close the Preferences dialog, and re-run the trade area analysis.
Article ID:000011160
Software:
  • ArcGIS Business Analyst Desktop
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
